Activity › Forums › Maxon Cinema 4D › Making an assembly happen via Mograph?
  • Making an assembly happen via Mograph?
    Posted by Lance Moody on November 16, 2015 at 8:16 pm
    Hi guys,
    Was wondering if anyone right be able to help me understand how I might make the following happen. I suspect it is easy but, as a relative newbie, can’t figure out an elegant solution.
    I have a Radial cloner with 12 objects (let’s just say they are spheres, each with a different material).
    I would like to have each of those objects rise up on the Y to a new position. Let’s say they are all at -500 on the Y and would like them to all end at zero.
    The thing is, I would like each clone to make it’s move randomly (and ease) into place. So they all end up at zero but each enters on its own schedule. I don’t want them to all end at the same time.
    Of course, I could make the cloner editable and animate the items individually but it seems like there ought to be a elegant Mograph way to do it.
    Any help appreciated.
    Lance
    Brian Jones replied 10 years, 10 months ago 2 Members · 3 Replies
  • Brian Jones
    November 17, 2015 at 3:42 am
    animate the object to be cloned, clone it and add a Random effector – in the Random Effector the important bits are
    -in the Effector tab: Min/Max (min = 0 not the default -100), Random Mode (Mode = Sorted but try the others to see what they do) and Seed (Seed set it to different numbers and the ‘spheres’ rise in a different random order)
    -in the Parameter tab: Time Offset – is the number of frames plus the number of animation frames all the clones will *finish* the animation in – in the example file a sphere rises in 30 frames (well 31 really, 0-30), if Time Offset is set to 15 frames all the spheres will be finished by frame 45 – if time offset is set to 150 each sphere will have time to rise all the way up before the next starts
    9467_randomcloneanimate.c4d.zip
  • Lance Moody
    November 17, 2015 at 4:25 pm
    Thanks! But since each object in the clone is different that really just means animating them all separately anyway, right?
    Lance
  • Brian Jones
    November 17, 2015 at 4:56 pm
    I think so (Adam might know something different), but the effector could still be used to control timing and order – you could animate all the objects together (if they all occupy the same space, just select, keyframe) and it’s the cloner that separates them. The same setup works on separately animated objects as well as one cloned object.
