Activity Forums Apple Final Cut Pro Legacy Making adjustments to offline clip info after logging… Easier way?
  • Making adjustments to offline clip info after logging… Easier way?
    Posted by Dominik Bochenski on May 21, 2005 at 7:07 am
    This has been driving me nuts….
    1. Let’s say I punch many many numbers in…. after doing so, I realize that I had the wrong reel number for some of them…. or let’s say I had video only selected and relaize that I want audio captured as well. Is there a way to adjust that info in numerous clips at the same time?
    2. How come when I try to adjust an offline clip’s timecode in’s and out’s, it seems to insert some sort of wacked number. Example: My clip ‘newfie 8’ had an inpoint of 00:43:26:00 and out 00:46:34:00. This was wrong. I needed the in to be 00:46:26:00. So, I look in the bin, and under the Media Start column I see my wrong number. I click on it, happy that I am allowed to change it this easily, and punch in my revised t/c. 00:46:26:00…. I press enter. Guess what, my media start is now 00:46:28:24 and my out has also shifted to some bizar number. I tried this under the clip info/loggin info tab as well.
    Is this some sort of ‘feature’ that I don’t know about.
    Please help guys.
    Dominik Bochenski replied 21 years, 3 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    May 21, 2005 at 12:07 pm
    [Dominik Bochenski] “1. Let’s say I punch many many numbers in…. after doing so, I realize that I had the wrong reel number for some of them…. or let’s say I had video only selected and relaize that I want audio captured as well. Is there a way to adjust that info in numerous clips at the same time?”
    1. Select the first “wrong” entry info in the Browser column
    2. Make the correction on that first “wrong” one.
    3. highlight and “copy” (Apple-c) THAT one,
    4. highlight all of the “wrong” ones (individually or in groups) in that column and hit “paste” (Apple-v).
  • Gunner Jones
    May 21, 2005 at 11:49 pm
    A clip’s originally logged duration seems to rule the clip, which is, dare I say, buggy behavior. The duration shouldn’t force the changed clip to remain the same length. You usually want it to be a different length, actually. Usually this happens when you are logging on the fly and you catch something good after your originally set Out point. You want to set a new TC number in the Browser for the Out Point. When you do, it screws up your In Point and re-calculates it due to the original duration.
    The duration of the clip should be calculated after the newly placed edit point is set.
    I believe that this has never really worked right. Here’s what I do as a workaround:
    I just memorize the TC Out point, enter the new In point and then re-enter the Out after setting the new In. That seems to work.
    G.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Dominik Bochenski
    May 25, 2005 at 9:49 pm
    Do you ever find that when you punch in a number it doesn’t stay the same. For example, I just did this.
    I wanted to change the in-point from 00:01:03:00 to 00:08:03:00.
    When I punch it in, I get 00:08:03:16. No matter what I do, I can’t get it to set the exact inpoint I Want.
    Have you seen this?
