Activity Forums Adobe After Effects Making a TV ad, trouble smoothly zooming in …
  • Making a TV ad, trouble smoothly zooming in …
    Posted by Robert Combs on October 22, 2008 at 2:50 pm
    Hi all,
    I have an image of the US Capitol which is 3872 x 2592. And I’m scaling from 19% to 48% over 4:06 seconds and the zoom isn’t very smooth. It sort of pulses as it pushes in.
    Is there any trick or “Rule of Thumb” as to how to smooth something like this out.
    -Rob
    thanks
    Giriraj Bakale replied 17 years, 10 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 22, 2008 at 4:53 pm
    First off, you may want to reduce the size of the image by 50% since you only require 48% of its current size. Secondly, try switching on Motion Blur. Thirdly, if these don’t help, then check your pixels/sec in the Graph Editor. Unless it is very low, you shouldn’t have any issues.
    Ah, also remember to check that the layer is set to Best Quality.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Giriraj Bakale
    October 23, 2008 at 10:34 am
    will what Roland R. Kahlenberg said is 100% true…
    but if u want u can even select the scale key frames and right click on
    any key frame you would get Exponential scale click on that option to get the smooth scaling
    For more information on Exponential scaling you can watch Earth Zoom tutorial of Andrew Kramer….
    hope you got the point……
    Giriraj Bakale
    Small Cow…
    India
