Making a subclip with Premiere Pro 1.5
In Premiere Pro 2, you can make in and out points in the source window and then drag the source window to your bin and it will create a sub clip based on the in and out points you specified.
I wanted to know how you can make sub clips in Premiere Pro 1.5? The above way doesn’t work. While I’m going through my video, I make in and out points that I will eventually drag down to my timeline, but how can I first drag sub clips to a bin?
Thank you
