Activity Forums Maxon Cinema 4D Making a stationary cloud with Pyrocluster
  • Making a stationary cloud with Pyrocluster
    Posted by Ben Black on October 19, 2009 at 10:48 am
    Hi
    Im trying to make some stationary clouds in C4D. Im using pyrocluster particles to do this which makes
    a decent enough cloud.
    The problem is because im using the clouds in an animation the particles will keep growing making the
    cloud much bigger than I want it.
    Is there a way to freeze the particles so they stop coming out of the emitter? I’ve looked into using Thinking Particles which has a function called PFreeze. Not worked out how to use it yet tho so not sure
    if im going in the right direction?
    Ben
    Brian Jones replied 16 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    October 19, 2009 at 11:06 pm
    Go into the Emitter settings and in the Particle section set the Start and Stop Emission values so it stops when the cloud is as you like it.
