Activity Forums Apple Final Cut Pro Legacy making a sequence and naming cuts from a single capured clip
  • making a sequence and naming cuts from a single capured clip
    Posted by Nelson May on August 12, 2006 at 1:16 pm
    I have been on sets for the past two weeks as well as shooting and I am brain dead. Sorry for the rookie question, but
    How do I make sequences and rename clips after rendering the whole tape. I am trying to work backwards for good bookeeping on a large edit.
    I also can’t get my video and audio clips to link so Ithey don’t separate when moving them around.
    Again I am brain dead, and any help would be appreciated.
    Howie Chin replied 20 years, 1 month ago 3 Members · 2 Replies
  • Tom Wolsky
    August 12, 2006 at 1:26 pm
    Not sure what you mean by render whole tapes, do you mean capture whole tapes?
    New sequence – Cmd-N
    What format is this? Break the material down into subclips to rename.
    Make sure Linked Selection is turned on Shift-L.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Howie Chin
    August 12, 2006 at 4:30 pm
    [nelsonmay10] “I have been on sets for the past two weeks as well as shooting and I am brain dead. Sorry for the rookie question, but
    Again I am brain dead, and any help would be appreciated.”
    To make sequences, just click Apple-N or Cmd-N…i love to call it apple..flows better in my sentence.
    You could actually rename the clips in the Browser after u’ve imported the clip…but if you need to re-connect the media, it just doesn’t trace back to the original clip because it uses the clip name that you’ve renamed in the browser.. hope you get that.
    If i may suggest, u keep the original media as it is…( the whole tape ? – uncut ) and import it into FCP…seperate them into different sequences…like one sequence is just a fighting scene or “Scene 1” depends how u wanna categorize it.
    and from there you can export it out to their own respective clips with their own name.
    Linking could be a mess. I’ve had my share of problem.
    Here’s the workaround.
    To link audio and video – hit Apple-L and you’ll see the clip name will have “underlined” names.
    note: link…and not group. it doesnt link when u pull Video A to link with Audio B…it’ll link back to Audio A
    and when it’s ou
    When u find yourself pulling the video off from the audio…
    hit Shift-L for Linked Selection. It should snap your Video and Audio to be pulled together.
    To unlink the stereo Audio… is Alt-L
    sorry for the long explanation.
    good luck
    [howie|chin]
    [howie]
