Activity Forums Adobe After Effects Making a Scoreboard
  • Kevin Camp
    October 18, 2011 at 4:25 pm
    you would set the scores up as text layers then animate the text value as the score changes.
    so you’d create a text layer and type 0 (zero) and set a keyframe for the text layer’s source text property. then at the point where one team scores, you’d change the text from 0 to whatever the new score is, ae will add a new keyframe to the source text property at that point. you’d just keep doing this process as you scrub through the game footage, then render that out.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Nick Vanderhoff
    October 18, 2011 at 5:29 pm
    Awesome thank you
