Activity Forums Apple Final Cut Pro Legacy making a mpeg4 file using compressor
  • making a mpeg4 file using compressor
    Posted by Kelly Laudien on September 11, 2010 at 8:23 pm
    In fcp I right click on seq and select export using compressor, then I search mpeg4 I see all the settings so I try one I drag it to box and then hit submit, but the file it makes looks like a compressor file not a mpeg4 and when I double click the file compressor opens and the dialog box. How do I make an mpeg4 file that I can just upload to my ftp for a client. thanks kelly
    Rafael Amador replied 16 years ago 3 Members · 3 Replies
  • Steve Eisen
    September 11, 2010 at 8:40 pm
    Do not use QT Conversion. Use Export QT Movie. Drop that file into Compressor and choose a preset for h.264. Hint, type in h.264 in the search tab to bring up the presets.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Kelly Laudien
    September 12, 2010 at 12:09 pm
    The problem I’m having is the file opens compressor when I double click on mpeg4, maybe its not self contained and I don’t know how to change that I choose export to compressor choose and mpeg4 file setting drop it in the box and then hit submit, it makes the file but when I double click it again compressor opens up.
    Help
    thanks kelly
  • Rafael Amador
    September 12, 2010 at 2:50 pm
    Do you Submit and when you go to close Compressor you chose SAVE?
    is that file the one you try to open?
    rafael
    http://www.nagavideo.com
