Activity › Forums › VEGAS Pro › making a low res file
  • making a low res file
    Posted by Roger Bansemer on May 2, 2011 at 10:13 am
    I’m needing to get a video file from someone who has a mac but I want a very low res image to keep the file as small as can be as image quality is not the issue.
    What format or settings can I suggest my friend use on his mac to create the file?
    John Rofrano replied 15 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    May 2, 2011 at 12:51 pm
    [Roger Bansemer] “I want a very low res image to keep the file as small as can be as image quality is not the issue.”
    Size is determined by bit-rate more than anything else. They could just send you a low bit-rate MPEG-4 AVC/H.264 file and that should still have pretty good quality with small file size.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
