Activity Forums Apple Final Cut Pro Legacy Making a FCP Movie with an alpha channel
  • Making a FCP Movie with an alpha channel
    Posted by Chris Woods on July 10, 2010 at 11:44 pm
    Not sure if this has been asked on these forums, but can you export a Final Cut or Quicktime file with an alpha like you can do in Photoshop? For example, if I had a Lower 3rd graphic and I added a transition two the beginning and end to it like an Edge Wipe, I know if I make that into a movie file and try to place it on video, they’ll be black in back of it. Is there a way to export it for it will have a transparent background? Thank you for your time.
    Tom Wolsky replied 16 years, 1 month ago 3 Members · 6 Replies
  • Tom Wolsky
    July 11, 2010 at 12:29 am
    Don’t render it. Export using the Animation codec with colors at millions+ or using the ProRes 4444 codec.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • John Doggett-williams
    July 11, 2010 at 2:36 am
    How do you export with a codec? do you insert the footage on a sequence with that setting?
    John doggett-williams
  • Tom Wolsky
    July 11, 2010 at 11:47 am
    Export QuickTime Movie. Select from the list provided. Use if ProRes 4444 if you can. Or use Custom from the bottom of the list.
    This rally should be in the basics forum.
    All the best,
    Tom
    July 11, 2010 at 12:08 pm
    thanks, just wanted to be sure.
  • Chris Woods
    July 11, 2010 at 7:44 pm
    Ok, thanks. I’ll try that. What if the file you have is all ready rendered?
  • Tom Wolsky
    July 11, 2010 at 10:52 pm
    Switch off the opacity and switch it back on.
    All the best,
    Tom
