Activity › Forums › Adobe After Effects › making a crowd with particular
  • Kyle Troxell
    April 18, 2007 at 7:03 pm
    wouldn’t duplicating that layer of a person over and over again and justlayering them all together work?
    as for particular, i have no idea
    “Sideways Falling”
  • Victor Nash
    April 18, 2007 at 8:06 pm
    This gets asked alot.. I’d do a search for this.. however here are some quick tips..
    Create your Composition with “1 person”,.. is this a still or video?
    This will be your “Custom” particle under the Particle Type.
    Set your Emitter to a Box emitter, and set the velocity to 0.
    Perhaps do an Emitter size of X for 1000 Emitter Size of Y for 0 Emitter Size of Z for 1000.
    You’ll have to let the particles generate however you can Pre-Run the Emitter with a percentage under OPTIONS.
    Physics Time Factor will stop the particles from generating Keyframe 1 to 0.
    If it’s a Looping Video, then I’d keep your video real short and under Time Sampling select Random Loop. This is off the top of my head right now.. but you’ll be able find a lot more detail in your search
    “kis” it
    Keep it Simple
  • Enrique Borja
    April 18, 2007 at 9:05 pm
  • Matthew Preis
    April 19, 2007 at 12:20 am
    I can’t get my crowd to be a big enough size. I have a greenscreen shot of one man one hime to be a huge crowd. I know you can only make the particle a certain size and I am dealing with video that is 1280 by 720…
  • Victor Nash
    April 19, 2007 at 11:59 pm
    Not sure, when you say crowd big enough size.. Just increase the amount of particles..? is that what you mean?
    “kis” it
    Keep it Simple
