Activity Forums Adobe Illustrator Making a circle semi-transparent
  • Making a circle semi-transparent
    Posted by Alex Williams on March 23, 2012 at 12:39 am
    Ok if I have roughly 10,000 circles, all of the same color, and I want to make them semitransparent (i.e. set each to have an alpha value of 0.5 or something like that), is there a way to do that in illustrator?
    Vincent Rosati replied 14 years, 5 months ago 2 Members · 1 Reply
  • Vincent Rosati
    March 23, 2012 at 11:08 pm
    Maybe just selecting all of the objects and setting the Opacity to 50% in the Transparency palette (Window / Transparency) would do the trick.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
