Activity Forums Adobe After Effects Making 3d airport lines on 3d model of earth
  • Making 3d airport lines on 3d model of earth
    Posted by Vivian Richardson on July 12, 2010 at 5:37 pm
    Hi there! Hoping someone can point me in the right direction:
    I’ve got a very hi resolution map of the earth I’ve sphereized in AE. I’m zooming out and my client would like arched lines coming from one point on the map (Orlando) to other places on the map. Kind of a high tech version of the Indiana Jones airplane lines.
    Has anyone seen a good tutorial for this?
    I do have trapcode particular and I’m working in CS4.
    Many thanks!
    David Superville replied 16 years, 1 month ago 4 Members · 4 Replies
  • Michael Szalapski
    July 12, 2010 at 6:07 pm
    How have you spherized this image? Use the same method, but make the sphere bigger on your lines.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Vivian Richardson
    July 12, 2010 at 8:58 pm
    Thank you, both for the ideas/tips. I did use CC sphere — Now it’s just a matter of making it look fancy. 🙂
  • Jens Enqvist
    July 14, 2010 at 8:14 am
    Like Michael suggested.
    A tip, if you want the lines to actually be straight spherical lines, you may want to check out CFX Sphere Utilities which contains MapLine that draws correct lines on spherical maps. There is a demo available at cycorefx.com. The package is designed to work with spherical maps and the special distortions required.
  • David Superville
    July 16, 2010 at 2:35 pm
    what i’ve done in the past is go back to the original earth texture, create a new solid and start creating masks that start at my place of origin and end at my destination (ie, first point in miami, second point in alaska.) i then generate stroke and animate it as needed. i then precomp this layer with the earth map texture and then “spherize” them.
