Activity Forums Maxon Cinema 4D make preview progress
  • make preview progress
    Posted by Tim Monaghan on July 29, 2012 at 5:56 pm
    Is there a way to know the progress of a “make preview” render?
    Or do just have to sit there and wait?
    Can you continure to work while the make preview is in progress?
    Tim Monaghan replied 14 years, 1 month ago 2 Members · 4 Replies
  • Brian Jones
    July 29, 2012 at 6:01 pm
    progress should be down on the lower-left – if that spot isn’t being used to tell you something else but it will come back eventually. Yes, you can work
  • Tim Monaghan
    July 29, 2012 at 6:06 pm
    Huh, I’ve got nothing in the lower left. Anyway to turn it on? R12 on a Mac.
  • Brian Jones
    July 29, 2012 at 6:31 pm
    it’s on by default in every single window layout, but it is possible to get rid of it if you are using a custom layout. It’s the same area that gives you feedback for every tool you roll over the area that says “Move Tool [Shortcut E]” if you mouse ever the Move tool etc. etc. etc.
  • Tim Monaghan
    July 29, 2012 at 7:44 pm
    Somehow I lost it on my startup layout. Found it when I switched to the default animation layout.
