Activity › Forums › Maxon Cinema 4D › Make new Brush from Booleans?
  • Make new Brush from Booleans?
    Posted by Jonson on June 16, 2007 at 5:58 pm
    Hi! I have following “problem” in Cinema4D: I will explain by an example:
    I want to have a cube with a hole in it: so I add a cube and then a cylinder. After that I put both in a Boolean-Object and with “A subtract B” I get my new Cube that has a hole in it; However I want to have an Object with this new special Form only – I don’t want to have the whole Procedure displayed in the Object-Manager with “NullObject-Boolean-Cube-Cylinder” – Tree, I want this new Object
    I already tried it with Object -> Duplicate, but this only makes a copy of the whole “boolean” thing and furthermore it also deletes the new shape when I delete the old objects.
    So my question is, how can I make this to be a single new Object?
    Jonson replied 19 years, 3 months ago 2 Members · 2 Replies
  • Nolan Scott
    June 16, 2007 at 10:36 pm
    Select the Boole-Object and make it Editable,
    select the
  • Jonson
    June 16, 2007 at 11:05 pm
    THANK YOU VEY MUCH!!! IT WORKS, FINALLY :-)))) !!
    THANKS AGAIN!
    j.o.
