Activity › Forums › Adobe After Effects › Make linear keyframe movement not as smooth
  • Make linear keyframe movement not as smooth
    Posted by Kevin Tosi on July 1, 2016 at 3:53 am
    I’m animating 2D and I’ve stopped using keyframes because the tweening is too smooth and looks unnatural. Like say for moving a character’s arm up, instead of linear keyframes with 2 positions, I’ll just use holds and do 3-4 positions in between manually so it jumps between position. Is there an expression or way to cut frames in between linear keyframes so I don’t have to manually do this?
    Thanks in advance!
    Kevin Tosi replied 10 years, 3 months ago 2 Members · 2 Replies
  • Roei Tzoref
    July 1, 2016 at 4:34 am
    how about working in lower FPS so the animation won’t have that many frames to go from on keyframe to another?
    you can even combine different frame rates as long as each are in a different composition and you have checked in the composition settings->advanced the “preserve frame rate” checkbox
  • Kevin Tosi
    July 1, 2016 at 5:58 am
    Interesting, I didn’t know you could combine comps with different fps so that should work, thanks!
