Activity › Forums › Adobe After Effects › make layers longer
make layers longer
Posted by Soffia on September 6, 2006 at 9:28 amWhen you make a comp longer, from fx 10 sec to 15 sec, how do you select all the layers on the timeline and make them as long as the new duration of the comp.
many thanks,
SoffiaSoffia replied 20 years ago 2 Members · 2 Replies -
Learnae
September 6, 2006 at 3:38 pmYou can click the top layer and then hold down Ctrl and select all the layers you want to be selected – this is a good way to do it because if there is a layer in there somewhere you don’t want selected you can bypass it by not clicking on that layer. Another way to do it is to select the top layer you want selected and go all the way to the bottom of all the layers and press Shift and while holding shift click on the bottom layer and all layers in between will be selected. If there is a layer that got selected in all that just press Ctrl and click the layer you don’t want selected and presto it’s not selected anymore but all the rest are that you wanted selected.
Once all the layers you wanted are selected put the mouse at the end of the layers and it will turn into a double pointed arrow and you can then drag them to the desired time.
Soffia
September 13, 2006 at 8:36 amwhen I select the layers and want to move them, I can only move one layer at a time (even though I select few layers at a time only one layer moves, the one the mouse is over) I put the mouse on the gray part at the end of the pink line. but it only makes the layer I have my mouse on longer. IF I put the mouse on the pink part I can move all the layers at the same time, but I
