Activity Forums Adobe After Effects Make blacks/dark areas glow instead of white/light areas?
  • Make blacks/dark areas glow instead of white/light areas?
    Posted by Michael Lansdell on March 12, 2009 at 2:04 pm
    I’m using 6.5, and I’m working on a project where I think it would be nice to make the dark areas glow black, instead of the usual light areas glowing white. But I can’t work it out, any ideas?
    Michael Lansdell
    Online Editor,
    Available Light Productions Ltd
    My system:
    2 x 3 GHz Quad-Core Intel Xeon
    5GB DDR2 RAM
    512MB ATI Radeon X1900 XT
    OS X 10.4.11
    Final Cut Pro 6.0.4
    Blackmagic Design DeckLink HD Extreme (6.6.2)
    Ronaldo Montalvo replied 17 years, 6 months ago 3 Members · 2 Replies
  • Kevin Camp
    March 12, 2009 at 2:16 pm
    i would think that you could apply the invert effect, then glow, then invert again. then make glow adjustments to see how it effects the layer.
    you could also try duplicating the layer add levels (or curves), then blur (like fast blur) to the top duplicate. set that layer’s blending mode to multiply or similar mode to only use the darker values. use the levels/curves effect to act like the threshold in glow and use the blur to act like the radius.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Ronaldo Montalvo
    March 12, 2009 at 4:58 pm
    try “glow” effect in multiply mode. adjust the threshold. the darks will bloom.
