Activity Forums Adobe After Effects Make bars from text rows
  • Make bars from text rows
    Posted by Andrei Popa on October 9, 2024 at 11:26 am
    Hi community, I need some help with a task of mine…
    I want to create some alpha masks from a text layer, to use with a duplicate of the said layer. I need every row to be a bar with the height dictated by the highest/lowest point in the respective row. I do not really care how big in width this will be, I just need it for some vertical alpha masking.
    Right now I am using “Minimax” effect, with a big radius (around 700-800), “Maximum” operation and “Just horizontal” direction. This works, but this seems to work slow on render, my project feels heavy even if I have only a few of these layers. I was wondering if there was an effect that used less resources and basically creates a long horizontal shadow of my entire row of text.
    Brie Clayton replied 1 year, 11 months ago 3 Members · 3 Replies
  • John Cuevas
    October 9, 2024 at 6:06 pm
    If you wanted to do each line as a single layer, you could lookup and use an automated shape box. Just google, there are lots of tutorials.
    If you want to do it with just effects. I did it by Adding a channel blur to the alpha, a levels effect to the alpha, a fill effect and then CC Composite. Please see my example project.
  • Andrei Popa
    October 10, 2024 at 9:24 am
    Hi John,
    Thanks a lot for the response. This is perfect. It looks a lot cleaner and it seems to take 10ms less per frame to render.
    I have only used the blur and level effects, since I use this as alpha, and don’t really care for inside colors.
    Thanks again for your response,
    Andrei
  • Brie Clayton
    October 10, 2024 at 7:46 pm
    Thank you for solving this, John!
