Activity › Forums › Maxon Cinema 4D › make a floor invisible and keep a shadow
Posted by Pablo Hill on August 6, 2008 at 1:47 amhow do I make a floor invisible but keep a shadow. I know how to do it on After Effects but not on C4D.
Nathan Jang replied 12 years, 2 months ago 6 Members · 9 Replies -
Zach Gunter
August 6, 2008 at 3:19 amis it live footage on the floor?
what material is under the floor, that you need to see?
Pablo Hill
August 6, 2008 at 4:18 amI tracked footage in PFhoe and export it to C4D, all the camera information is there. I added text and added a floor to crate the text shadow. Now I need to make the floor invisible but still be able to see the projected shadow.
Randy Johnson
August 6, 2008 at 5:03 amTo make the floor inviible place a compositing tag on it and in the atttributes turn off “seen by camera” and make sure receive shadow is checked on.
Then to render seperate use a multi-pass render with shadows checked. It will come with a white background so just multiply it over the rest.
/randy
Pablo Hill
August 6, 2008 at 2:50 pmI’ve done that and it’s not working. I was missing the multiply tag at render settings. But I’m still not getting a shadow.
Randy Johnson
August 7, 2008 at 7:25 amThen you need to use an object buffer instead.
Also in the composite tag and needs to be activted in the multi-pass./randy
Will Salley
September 22, 2008 at 9:06 pmI’ve got the same problem. Is it a bug?
I’m on V10.1.1 Mac
Primary System Info
Mac Pro 2×3.2 Quadcore – 10.5.4 – QT 7.5 – 6MBram – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro (v6.7)- Open GL 1.5.6 – Wacom Intous2 tablet -
Nathan Jang
April 2, 2013 at 10:59 pmNo, you can use Shadow Catcher, create a texture uncheck everything, then turn on alpha, then add the texture as Shadow Catcher. Now drag the Texture to the Floor
Sebastian Alvarez
June 29, 2014 at 10:26 pm[Nathan Jang] “No, you can use Shadow Catcher, create a texture uncheck everything, then turn on alpha, then add the texture as Shadow Catcher. Now drag the Texture to the Floor”
Hi, I found this old thread because I started experimenting with Cinema 4D Lite today and I’m going crazy trying to find a way to make a layer behave like a shadow catcher. I can do that easily in Modo, Lightwave and After Effects, but all the Google results about this took me nowhere.
What you say here, can you please elaborate a little bit on that? I tried it, but you say “…then add the texture as Shadow Catcher.” I haven’t found a way to do that, and in the manual searching for shadow catcher doesn’t bring any results. Is it because I have the Lite version? It’s the one with CC 2014.
Sebastian R. Alvarez
Nathan Jang
June 29, 2014 at 10:37 pmThis should be all the information you need: https://www.grafxflow.co.uk/tutorials-and-tips/cinema-4d/shadow-catcher-plugin-in-cinema-4d/
