Activity Forums Apple Final Cut Pro Legacy Make 50fps to 25fps for EDL ?
  • Make 50fps to 25fps for EDL ?
    Posted by Ola Haldor voll on August 23, 2010 at 12:17 pm
    I’m grading a video for a client. Footage is 720p@50fps. I need to export using EDL to bring it further down the chain, but as far as I know, EDL won’t work with 50fps. So I guess I need to make this 25fps..
    I tried using Media Manager, but found no solution. I select “recompress” and Prores 422 HQ 25fps, but I’m getting an error message that the setting won’t apply to the fps of the clips being recompressed.
    I’m a bit stuck here!
    Rafael Amador replied 16 years ago 2 Members · 3 Replies
  • Rafael Amador
    August 23, 2010 at 12:28 pm
    Hi Ola,
    Just drop the clips in a 25p sequence and export.
    One every two frames will be dropped.
    If you have a lot of stuff, you can batch export with Mpgstreamclip.
    rafael
    http://www.nagavideo.com
  • Ola Haldor voll
    August 23, 2010 at 12:41 pm
    Hmm well, I tried that. In the grading application it will play all 50fps even though the timeline is 25fps, so the video looks slow motion.
  • Rafael Amador
    August 23, 2010 at 12:59 pm
    Hi Ola,
    You should be getting a 25p file with the same length than the original.
    I don’t know what you are doing wrong.
    rafael
