Activity Forums VEGAS Pro Major Rendering Issue – Please Help!
  • Major Rendering Issue – Please Help!
    Posted by Chelsea Volz on October 12, 2008 at 10:37 pm
    I’ve posted here before regarding this issue, however, I thought it was pertaining to my entire program.
    Well, I’ve been working on this video for the past few months, I finally finished it. It’s a little over three minutes long, contains alot of transitions. It has 3 Audio tracks and three video tracks.
    At one point,after attempting to render it my program would shut down and once I couldn’t open the video at all. Then someone told me to open the .veg.bak file and it worked. I was ecstatic. However, I still cannot render the video at all. I’ve tried rendering it in sections. Rendering a minute of the video to attempt to open and then go back and render another minute, etc. But, each and every time I attempt to render the video, it gets to about 4% (never exact) and my entire program freezes and then it shuts down.
    Sometimes I get an Error Message like this one:
    An error occured during the current operation.
    An Exception has occurred.
    Sony Vegas 7.0
    Version 7.0e (Build 216)
    Exception 0xC0000005 (access violation) READ:0xBF71000 IP:0x7255507A
    In Module ‘MSVCR80.dll’ at Address 0x72540000 + 0x1507A
    Thread: ProgMan ID=0x17B0 Stack=0x3D8F000-0x3D90000
    Registers:
    EAX=0c06d200 CS=001b EIP=7255507a EFLGS=00010216
    EBX=00000000 SS=0023 ESP=03d8f510 EBP=03d8f518
    ECX=0003f080 DS=0023 ESI=0bf71000 FS=003b
    EDX=00000000 ES=0023 EDI=716010a8 GS=0000
    Bytes at CS:EIP:
    7255507A: F3 A5 FF 24 95 94 51 55 …: 72 90 8B C7 BA 03 00 00 r…….
    Stack Dump:
    03D8F510: 00000000
    03D8F514: 0A7DFA00 0A710000 + CFA00
    03D8F518: 03D8F88C 03C90000 + FF88C
    03D8F51C: 3A1073D3 3A0F0000 + 173D3 (wmfplug3.dll)
    03D8F520: 716000A8 71600000 + A8
    03D8F524: 0BF70000 0BF70000 + 0
    03D8F528: 000FD200 00030000 + CD200
    03D8F52C: B9186756
    03D8F530: 3D4F4308 3D1D0000 + 324308
    03D8F534: 57947B0C 56DB0000 + B97B0C
    03D8F538: 57947AD8 56DB0000 + B97AD8
    03D8F53C: 33564D57 334A0000 + C4D57
    03D8F540: 00100000 00030000 + D0000
    03D8F544: 00000001
    03D8F548: 00000000
    03D8F54C: 000002D0
    > 03D8F638: 778F2447 77890000 + 62447 (ntdll.dll)
    > 03D8F64C: 008AF0F2 00400000 + 4AF0F2 (vegas70.exe)
    03D8F650: 00260000 00260000 + 0
    > 03D8F654: 23D8EB3F 23360000 + A2EB3F (QuickTime.qts)
    03D8F658: 03D8F598 03C90000 + FF598
    03D8F65C: 00000000
    > 03D8F668: 3508A177 35020000 + 6A177 (sftrkfx1.dll)
    > 03D8F66C: 350F7114 35020000 + D7114 (sftrkfx1.dll)
    > 03D8F670: 350F7118 35020000 + D7118 (sftrkfx1.dll)
    > 03D8F67C: 0075ADB6 00400000 + 35ADB6 (vegas70.exe)
    03D8F680: 00000008
    03D8F684: 3B944308 3B230000 + 714308
    03D8F688: 3B939064 3B230000 + 709064
    03D8F68C: 00000000
    > 03D8F69C: 0075BD98 00400000 + 35BD98 (vegas70.exe)
    03D8F6A0: 00000000
    > 03D8F6A4: 0075BDD5 00400000 + 35BDD5 (vegas70.exe)
    03D8F6A8: 03F03888 03E90000 + 73888
    03D8F6AC: 03F03880 03E90000 + 73880
    03D8F6B0: 03F03888 03E90000 + 73888
    03D8F6B4: 00000000
    > 03D8F6C0: 3973B128 396A0000 + 9B128 (vegas70k.dll)
    > 03D8F6D8: 00D8F854 00400000 + 98F854 (vegas70.exe)
    03D8F6DC: 00000000
    03D8F6E0: 00000000
    03D8F6E4: 00000000
    03D8F6E8: 00000000
    > 03D8F714: 3973B128 396A0000 + 9B128 (vegas70k.dll)
    > 03D8F740: 3973B128 396A0000 + 9B128 (vegas70k.dll)
    > 03D8F758: 00AB24E8 00400000 + 6B24E8 (vegas70.exe)
    03D8FFF0: 00000000
    03D8FFF4: 00519B40 00400000 + 119B40 (vegas70.exe)
    03D8FFF8: 00A80370 00400000 + 680370 (vegas70.exe)
    03D8FFFC: 00000000
    Other times it just shuts down.
    Now, I stopped using Sony Vegas for a long time because I thought this would happen to all of my videos upon trying to Render them. Someone also told me that the problem was just that I needed more memory and thats why I couldn’t render any other videos. But then a couple days ago I actually rendered tow other videos and I’m assuming I can render all of my other ones as well.
    The problem only seems to pertain to this video.
    Now, the reason I’m latching on to this video so much is because it’s my prize. I’m incredibly proud of it and I want to do whatever necessary to preserve it.
    John Rofrano replied 17 years, 10 months ago 3 Members · 37 Replies
  • 37 Replies
  • John Rofrano
    October 13, 2008 at 10:48 am
    These problems are usually very hard to find. How much memory do you have? What format are you rendering to? Have you tried rendering to a different format? Also what format are the clips on the timeline? I can see both Quicktime and Windows Media in the dump you posted. Make sure you have the latest versions of Quicktime and Windows Media Player if that’s what you are using. You can also try rendering some of your source files to a different format that doesn’t cause the error and replace them in the media pool. There is something about the combination of source types and render type that is causing the problem and you just have to figure out what that combination is and avoid it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chelsea Volz
    October 13, 2008 at 4:26 pm
    I have 2038 MB of RAM. My operating system in Windows Vista Home Premium – 32 bit. And my processor is an Intel(R) Core(TM)2 Duo CPU T5250 @ 1.50GHz – Not sure if you need any of that … I was planning on purchasing 1GB more of memory. Would that help?
    The majority of the video clips in the timeline are WMV… I wasn’t even aware some of the clips were Quicktime. But I will redownload the latest versions of both Quicktime and Windows Media Player.
    And yes, I have attempted to render the video in AVI, WMV and Quicktime formats, but they all crash.
    How do I determine which format is causing the problem? What do you mean/How would I render some of the source files to a different format and replace them in the media pool? Do you mean re-download the clips and replace them in the timeline? Or just render the entire video in a different format? Or sections of the video?
    I’m sorry for all the questions, I’m pretty much helpless when it comes to all of this technical stuff… But I can learn quick! So please don’t be discouraged to help…
  • John Rofrano
    October 13, 2008 at 11:54 pm
    With that processor I assume this is a laptop. That’s not a lot of computing power for a heavily compositied project. Perhaps the CPU is overheating? This could cause memory READ errors.
    What I mean is start a new project and take the video that is the source of the first event and drop it on the timeline and render it to a DV AVI file. Then load the original project back up and go to the Project Media tab and find the video for the first event and right-click and select Replace… and point to the DV AVI file that you just rendered. This will replace the file everywhere that it is used in the project. Then try and render the project and see if it gets past the first event. If it does (and it didn’t before) take more of the WMV source files and render them one at a time to DV AVI files. Then replace them one at a time in the Project Media. If this allows the render to continue then you know it’s something about the WMV files that is causing the problem. Since you couldn’t render even a minute it shouldn’t take too long to tel if this approach is working.
    ~jr
  • Chelsea Volz
    October 14, 2008 at 12:37 am
    When you say “the video that is the source of the first event and render it to a DV AVI file.”, you mean the the entirety of the WMV video, not just the small clip I manipulated, correct?
    Because the very first event that is in my timeline is just text from the Generated Media with my logo, etc.
    Anywho… I’ve began rendering the original video clip I used, the first actual piece of media/video in the project. I will follow the rest of the steps as I understand them. I will come right back to let you know if it has worked and if it doesn’t, I will ask you the other questions…
    I’m only wondering because I’ve used these same clips in other projects that I’ve been able to render.
    P.S. – When I go to Render > Type, I don’t have the option of DV – AVI, I only have a .avi (media for windows) option. I’m not sure if that is the same thing…
  • John Rofrano
    October 14, 2008 at 12:46 am
    Yes, I believe you understood the “intent” of my directions. For DV AVI use the AVI type with the NTSC DV or PAL DV (or their widescreen counterparts) templates depending on the attributes of your project.
    It is odd that these clips work in other projects. Perhaps it’s not the clips themselves. It could be a corrupt project file. You could try opening a new project simultaneously and cutting and pasting the events between them.
    I’m just trying to thing of things to try to get you around this.
    ~jr
  • Chelsea Volz
    October 14, 2008 at 12:54 am
    I’m not exactly sure, but I really appreciate all of your ideas. If there is a snag somewhere while doing this process, I will follow your next idea.
    I’m not at all sure what NTSC DV or PAL DV are, but it seems to be working without that knowledge…
    This approach is definitely working. I’ve been able to get it almost 33% of the way rendered using this process.
    Is there something I can do to fix the WMV files because I have ALOT of DIFFERENT clips in this video and rendering all of these one by one would take a MILLION years, not to mention all of the space that it would consume because I would need to have a seperate render for each clip…
    If I must do it this way, then of course, I will.
    Just let me know, please. 😀
  • John Rofrano
    October 14, 2008 at 1:05 am
    Wow, I’m glad it’s working. You could try a batch converter like Super(c) to convert all of the WMV’s to DV. WMV is really an output format and it’s very good for editing. It works, but DV AVI is much more efficient for editing.
    ~jr
  • Chelsea Volz
    October 14, 2008 at 1:50 am
    Okay. So I just downloaded Super(C) and it’s asking me for all of this information I have no idea about.
    #1. Select the Output Container (there are all sorts of options but I chose WMV, just let me know if that is wrong.)
    #2. Select the Output Video Codec (Because I chose WMV, there are these options: MS – mpeg4 – v1, MS-mpeg4 – v2, WMV7, WMV8)
    #3. Select the output Audio Codec (For question number 2, i answered WMV8, but I dunno… There are these options since I’ve chosen certain answers, I guess: ADPCM IMA, ADPCM MICROSOFT, mp3, wma)
    Then there is a section that says: Internal Encoders are Auto-Selected to Complete This Operation. And “FFmpeg” is chosen out of the following options: FFmpeg, MEncoder, FFmpeg2theora, RealProducer
    There is a Video Section with the following options:
    Disable Video
    Stream Copy
    Video Scale Size with ratios ranging from 128:96 to 480:320 or no change.
    Aspect Option with ratios ranging from 1:1 to 16:9
    Frame/Sec with the options: 23.976, 29.97, 25, 30
    Bitrate kbps Section with the options ranging from: 768 to 29,040.
    Then there are Quality Options: Hi-Quality, Top Quality, Stretch It, 48K Audio…
    Then there is an Audio Section with the following options: Disable Audio & Stream Copy.
    Under Sampling Freq there are the following options: 22050, 44100, 32000, 48000
    There is a Channels Option with 1 or 2 available.
    Bitrate kbps option with: 32, 48, 64, 80, 96, 128, 160, 192.
    DVD Language Select AudioStream Track # with options: default, and then 1-24.
    Then there is an OutPut section that says:
    Encode to File Format: WMV
    Use Video Codec: WMV8, 384:288(4:3), 768 kbps, 25fps
    Use Audio Codec: wma, Stereo, 64 kbps, 44100 Hz, AudioStream(default) selected
    Then there is a final section that tells me to drop a valid multimedia file and it will try to play or encode.
    And finally, it gives me the option to: Encode(Active Files)
    Play(Active Files / Streams)
    Play the last Rendered File
    Player Options
    and
    Cancel All
  • John Rofrano
    October 14, 2008 at 2:21 am
    Actually you don’t want WMV as the output container because you are trying to make AVI files. If your project is NTSC try these settings:
    1. Output Container: avi
    2. Output Video Codec: M-JPEG
    3. Output Audio Codec: WAV-(pcm 16 little-endian)
    [x] MEncoder
    Video: (no change)
    Aspect: 4:3
    Frame/Sec: 29.976
    Audio: (no checks)
    Sample Freq: 48000
    Channels: 2
    This should give you a file that can be rendered easily in Vegas. You should try and match the properties of the source files as closely as possible. If you project is PAL use 5:4 aspect and 25 fps instead.
    ~jr
  • Chelsea Volz
    October 14, 2008 at 2:49 am
    How do I check what settings my project is in? o.O
    -Sorry if that’s a stupid question…
Page 1 of 4
