Activity Forums Apple Final Cut Pro Legacy Major problems when trying to Capture!
  • Major problems when trying to Capture!
    Posted by Austxdan on June 18, 2007 at 6:54 pm
    I did a shoot with a Canon XL2 and I didn’t lay down time code. Now when I try to log and capture, it says this:
    “Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.”
    It does this every time I try to start capturing again, so in User Preferences:
    I UNCHECKED THE FOLLOWING WITH NO LUCK:
    Sync audio capture to video source if present
    Report droopped frames during playback
    Abort ETT/PTV on dropped frames
    Abort capture on dropped frames
    It still keeps stopping and giving the above error message. Any suggestions???
    Dan
    Dunwoody Lampton replied 19 years, 2 months ago 2 Members · 1 Reply
  • Dunwoody Lampton
    June 19, 2007 at 1:06 am
    Just LAST NIGHT my XL2 was feeding F.C.E. 3.5 HD with timecoded tape.
    However, every time it hit a break in timecode – due to tape shifting between powering down and powering up with the same tape in the camera – capture would halt and show the “searching for timecode break” message.
    I went into Easy Setup and selected DV Converter instead of Firewire Basic, operated the XL2 manually instead of through F.C.E., and had no problems during the remainder of a 48 minute capture session.
    Good luck.
