Activity › Forums › Adobe After Effects › Maintain Distance Expression
  • Maintain Distance Expression
    Posted by Jake Smith on January 11, 2013 at 5:18 pm
    Hello!
    I am trying to have 2 layers maintain their distance between each other. So the idea is that if layer A is at 0,0 and layer B is at 500,500. If layer A moves to 100,100 then layer B would move to 600,600 and could never go below or above that 500 offset.
    Does this make sense? Any help would be greatly appreciated!
    Joe
    Walter Soyka replied 13 years, 8 months ago 4 Members · 6 Replies
  • Kevin Camp
    January 11, 2013 at 5:58 pm
    you could parent layer B to layer A and offset B and set B’s position to 500,500. B will always keep that offset from A.
    but an expression would be pretty simple:
    target = thisComp.layer(“A”); // make sure your layer A’s name is in the “”
    A.position + [500,500]
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Vishesh Arora
    January 11, 2013 at 5:59 pm
    Set the Final Position of both the layers and then parent both to a Null Object(say at [250,0], center of both layers).
    No need of Expression.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Kevin Camp
    January 11, 2013 at 6:30 pm
    sorry, i just noticed a mistake in the expression… the last line should be:
    target.position + [500,500]
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jake Smith
    January 11, 2013 at 7:00 pm
    Thank you for the quick responses! I think I might have phrased what I was looking for incorrectly. I think what I’m looking for is a way to keep an object away from another based on a radius.
    I am attaching an image where object B would always stay on the perimeter of the circle. Hopefully this will make a little more sense.
  • Kevin Camp
    January 11, 2013 at 7:38 pm
    that ups the ante a bit.
    i’m not sure what you want to happen if a or b get within a 500 pixel radius, but would a repel expression work, where either a or b wold push the other out of the way?
    https://colinbraley.com/repel_expressions_tutorial.html
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Walter Soyka
    January 11, 2013 at 8:12 pm
    [Jake Smith] “I am attaching an image where object B would always stay on the perimeter of the circle. Hopefully this will make a little more sense.”
    Rather than mucking with position, let’s use rotation to keep B on the edge of the circle.
    Let’s assume three layers:
    B
    A
    Circle
    where A & Circle are at the center of the comp.
    Create a null object at the center of the comp, and name it Rotator. Parent B to Rotator, and adjust its position such that B sits on the circle. (To sit it at twelve o’clock on a circle of radius 500, you could make its position [0,-500], because the position is now relative to its parent.)
    Tap R on the B layer to reveal its rotation property, and alt-click the stopwatch. Add the following expression:
    -thisComp.layer("Rotator").transform.rotation
    Now, keyframe Rotator’s rotation property however you like. As you adjust it one way, B’s rotation property will automatically adjust the other way, keeping B level and making it appear to travel along the circle’s perimeter.
    Walter Soyka
