Maintain Audio Pitch
Hey
I’ve got a voiceover for a film I’m making that needs to be sped up but maintain the same audio pitch.
I’ve selected the maintatin audio pitch checkbox in the speed/duration menu but an error message pops up saying “Disk Write Error – Verify Drive Connections, available disk space and disk access privileges.’ The title of the error is ‘Audio Preview Error’. This only happens when I try to play it, and if i switch of maintain audio pitch it plays (high pitch) without error.
So then I tried to adjust the pitch manually with the Pitchshifter tool which works. Except if you render the preview or export – if you do either of those things the voiceover just doesn’t play at all.
I’m using Adobe Premiere Pro 7.0 with standard PAL DV footage.
Any Ideas?
