Activity Forums Adobe Encore DVD Main Timeline
  • Main Timeline
    Posted by Jared Boice on April 5, 2010 at 3:08 pm
    quick question regarding a Main Timeline. I’m making a DVD (as well as Blu-Ray) project that doesn’t reallly have a main timeline, it’s a bunch of different showcases and events. Is it possible to set a Playlist as a Main Timeline ? Or if you set the Main Timeline to a timeline with an end action that links to another timeline, will the Main Timeline respect this feature when selected so it could play all the timelines?
    Just curious, thanks!!
    Amit kumar Gupta replied 16 years, 5 months ago 3 Members · 3 Replies
  • Jeff Bellune
    April 5, 2010 at 4:27 pm
    The “Main Timeline” is just the timeline that gets written to disc first. Otherwise, the timeline order on the disc will be the order that you create the timelines.
    AFAIK, you shouldn’t be able to set a Playlist as the Main Timeline; did you try it? What happened?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Jared Boice
    April 7, 2010 at 3:15 pm
    Thanks for the info, you were right on not being able to use a playlist. Thanks!!
  • Amit kumar Gupta
    April 13, 2010 at 8:56 am
    Main Timeline is the Timeline that plays when you press Stop button twice in DVD remote and then press Play button. This works for DVD only.
    Playlist cannot be added as Main Timeline.
    >> Yes, this should work
