Activity Forums Sony Cameras main REC button problem EX3
  • main REC button problem EX3
    Posted by Enrique Orozco on September 14, 2009 at 5:13 pm
    I don’t know if I’m the only one but I’m experiencing problems with the REC button (the one on the “grip”) from my EX3…. after a few minutes working with the camera, the button begin to “slip” inside the grip starting from its upside part …. I have to “pull it” out to its place again to make sure it will work …. What bothers me most is that I just received the camera from Sony precisely because of this problem and for updating the firmware (solved focus problems)….
    The notes on the warranty packing list just said:
    “Final solution: The rubber cover for the rec button was out of place.”
    … yes they put the rubber cover again in place, but USING the button several times makes the problem reveals again….
    any suggestions from the experts would be greatly apreciated…
    It is really AMAZING why supposed PRO equipment has this kind of problems !!
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Enrique Orozco replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
