Activity › Forums › Maxon Cinema 4D › main menu? lost !
  • main menu? lost !
    Posted by Eric Daurat on October 6, 2008 at 6:33 pm
    Hi everybody!!
    in my work space, the main menu that give access to all resources has disapeared. the only word left is ” file”, and when I clic on it, the only option suggested is “close”. I must have done something wrong as a command, and I do not find how to restore the full interface… I am desperate 🙁 …
    Please give help! thank you in advance!
    Eric Daurat replied 17 years, 12 months ago 3 Members · 3 Replies
  • Randy Johnson
    October 6, 2008 at 8:14 pm
    you just changed your viewport. There is a botton under the back arrow click on that and get the viewport options. After you pick the one you want you can save it as your start up view Window:layout menu.
    /randy
  • Lennart Wåhlin
    October 6, 2008 at 8:16 pm
    Try Shift+F12 to open the CommandManager.
    Search “layout” and choose “Default Layout” or “Reset Layout” and Execute.
    Cheers
    Lennart
    aka tcastudios
  • Eric Daurat
    October 9, 2008 at 6:47 am
    Well, thanks so much!! it was so obvious that i did not see it!! and, by the way, i am new on this forum, and it seems very active. I will keep an eye on all that! thanks again!
