Activity Forums Adobe Premiere Pro Magnification in CS4
  • Magnification in CS4
    Posted by Laurie Doering on September 11, 2009 at 1:15 am
    I am new to Premiere Pro and working on my first project.
    The program monitor window is showing the video magnified in comparison to the source monitor window. Both windows are set to fit but I am getting a magnified portion of the video in the program monitor. How do I get the same field of view in both source and program windows.
    Laurie Doering replied 17 years ago 2 Members · 2 Replies
  • Mike Velte
    September 11, 2009 at 10:33 am
    Your source video is likely larger in resolution than your Sequence setting and does not fit into the Program window.
    One solution would be to right/click on the video in the timeline and choose “Scale to frame size”.
    A better solution would be to set your Sequence settings to match your source video.
    Use Premiere (File>Get Properties for…) to determine the Properties of your source video and let us know.
  • Laurie Doering
    September 11, 2009 at 9:35 pm
    Here are the properties of the video:
    File Path: C:\Storm video_ August 9, 2009\P1000548
    Type: QuickTime Movie
    File Size: 50.2 MB
    Image Size: 1280 x 720
    Pixel Depth: 24
    Frame Rate: 30.00
    Source Audio Format: 16000 Hz – 16 bit – Mono
    Project Audio Format: 32000 Hz – 32 bit floating point – Mono
    Total Duration: 00:01:15:15
    Average Data Rate: 680 KB / second
    Pixel Aspect Ratio: 1.0
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).
    Video:
    There are 1133 frames with a duration of 1/30th.
    Video track 1:
    Duration is 0:00:02:11
    Average frame rate is 15.01 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 1280 x 720
    Compressor = Photo – JPEG
    Quality = Normal (3.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 16 bit – Mono
    Rate = 16000.0000 Hz
    Compressor = 16-bit Big Endian (uncompressed)
