Activity › Forums › VEGAS Pro › Magix Vegas Pro 16 – Unmanaged Exception (0xc0000094)
  • Magix Vegas Pro 16 – Unmanaged Exception (0xc0000094)
    Posted by Ilona Konovalcika on September 13, 2018 at 11:17 pm
    Hello. I have such problem with Magix Vegas Pro 16. It comes during the program start. Maybe someone could help me?
    Thanks in advance ????
    P.S. If it`s needed: my operation system is Windows 10 64 bit. If any other information is needed, please ask (cause I don`t know what can be needed to understand this problem).
    Problem Description
    Application Name: VEGAS Pro
    Application Version: Version 16.0 (Build 248)
    Problem: Unmanaged Exception (0xc0000094)
    Fault Module: C:\Program Files\VEGAS\Vegas Pro 16\Audio Hardware Drivers\sfasio.dll
    Fault Address: 0x00007FFA435CC9BC
    Fault Offset: 0x000000000018C9BC
    Fault Process Details
    Process Path: C:\Program Files\VEGAS\Vegas Pro 16\vegas160.exe
    Process Version: Version 16.0 (Build 248)
    Process Description: VEGAS Pro
    Process Image Date: 2018-08-15 (Wed Aug 15) 13:59:40
    Ilona Konovalcika replied 8 years ago 3 Members · 5 Replies
  • Mike Kujbida
    September 13, 2018 at 11:43 pm
    It may not help but it’s always a good idea to make sure your running the latest build first.
    261 is available here:
    https://www.vegascreativesoftware.info/us/forum/vegas-pro-16-update-1-build-261–112767/
  • Ilona Konovalcika
    September 14, 2018 at 12:00 am
    Don`t help, but whatever thank you 🙂
  • Graham Bernard
    September 14, 2018 at 12:12 am
    [Ilona Konovalcika] “C:\Program Files\VEGAS\Vegas Pro 16\Audio Hardware Drivers\sfasio.dll“
    * Grazie
  • Graham Bernard
    September 14, 2018 at 12:20 am
    That Fault Module Line indicates to me that you are having an issue as Vegas attempts to make a connection to some Audio Device or you’ve got some Audio SFX that requires the use of ASIO Drivers. Are you using an external Sound Card that requires ASIO Drivers? I have an external PreSonus AudioBox that requires ASIO Drivers. The Box is connected via USB. Sometimes I’ve needed to unplug the device and reconnect. I’d check that my ASIO Drivers are up to date.
    * Grazie
  • Ilona Konovalcika
    September 14, 2018 at 1:26 am
    Thank you for your answer ☺ But, surprisingly, I don`t have any external sound card. Actually don`t know what requires these ASIO drivers.
