Magix Vegas 17 Pro Build 387 AVCHD rendering error
Just installed the newest version and now I can’t render using AVCHD templates. Never had a problem with previous versions.
When i select any of the AVCHD Templetes, I get this popup
AVCHD 1920×1080-60i
“The selected encode format requires the download
of an add-on software module the first time the format is used
If you wish to proceed, Click yes.”I click yes, Then another error occurs…
“An error occurred while creating the media file. The reason for the error could not be determined”
Is there a fix for this?
