Activity Forums Adobe Premiere Pro Magic Bullet Looks: adjust keyframe fro preset
  • Magic Bullet Looks: adjust keyframe fro preset
    Posted by Deleted User on September 17, 2020 at 7:20 pm
    I am embarrassed even asking, but, I stepped away from the ”editing bay ” for a bit but now Im missing the creative output…Anyway:
    Im trying to adjust the amount or intensity of a MB effect in Premiere (CS6, I know its older). I see a multitude of ways to adjust aspects of a preset using key frames, but not an overall ”amount”-type slider.
    What I am trying to do is just gradually introduce an effect without having to make an effected dupe track above and change the opacity of that track. Am I overlooking that slider in the MB controls? I do not see a slider (for MB used in this instance) for this in the Premiere effects controls panel either.
    Thanks in advance.
    Troy
    Jim Curtis replied 6 years ago 2 Members · 1 Reply
  • Jim Curtis
    September 21, 2020 at 11:22 pm
    If you have an older version of Looks that doesn’t have the keyframable Amount slider, you can split your clip with the Razor tool, apply two different looks to each section, and add a dissolve between them.
