Magic Bullet/ Colorista (bummed)
Posted by Thomas Roberts on June 29, 2011 at 4:01 pmRed Giant no longer supports Sony Vegas Pro……Why??? Totally bummed today….
The new Red Giant Release has a ton of features I want…..Now my expensive options are After Effects or Jumping over to FCPX + new laptop, Adobe……
Why???
Thomas Roberts replied 15 years, 2 months ago 2 Members · 4 Replies -
Shawn Bossick
June 29, 2011 at 5:30 pmI agree, the last time I tried to use magic bullet it would not work on a 64 bit operating system, I talked to red giant in person about that, & at that time it was not profitable for them to spend all the necessary time to become 64 bit compatible, that was a year ago,
now I see your post, not supporting Vegas, RED GIANT WHY ? bummed too!!
Shawn Bossick
June 29, 2011 at 5:51 pmABSOLUTELY first & foremost in this order is how I use to color or effect clips within Vegas
insert the levels plug-in use your scopes to adjust your blacks & whites to optimum levels, go to help files to learn about your scopes A MUST LEARN for ANY editor!
second I will insert the plug-in CHANNELS,
the capability’s are AMAZING
again pull up your help files on Vegas & search for the plug-in CHANNELS there it will give you the information you need to learn this GREAT FEATUREmost likely this will take you some time to learn HOWEVER once you have learned this plug-in then you will be recommending it too.
for me this will take care of my levels & coloring
NOW effects wise like MAGIC BULLET
Vegas has a plug-in called SOFT CONTRAST it’s the closest thing Vegas has to MAGIC BULLET I use it for WEDDINGS all the timebetween these 3 items I can do WONDERS have fun.
