Activity Forums Adobe Premiere Pro Made the BIG switcheroo
  • Tom Daigon
    October 1, 2012 at 2:46 pm
    Greg, just a side note.After years with a 2008 Mac Pro running the Q4000, I also switched to a PC.
    After lots of research into tests performed by editors, I realized the best bang for buck would be running a GTX 570, not the Q2000 that my HP Z820 came stock with.
    I find it interesting that editors in the field that primarily use PrP and AE are realizing that the big push by Nvidia and Adobe for the Quadros is not the way to go with the high performance of the current generation of this kind of card.
    I know the word “professional” is bandied about a lot when comparing the Q and the GTX cards, but lots of statistics indicate which is the best bang for buck AND performance.
    https://forums.creativecow.net/thread/2/1019643
    https://ppbm5.com/Benchmark5.html
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Greg Estes
    October 1, 2012 at 3:04 pm
    Understood.
    We design GeForce primarily for gamers and exclusively for consumers and there are a handful of features in Quadro that make a difference for pros. Totally get it that many users will compare raw performance of a GeForce with that of a Quadro and find GeForce is as fast (or faster due to overclocking, etc.) In other cases Quadro will be faster.
    The value of Quadro isn’t necessarily speed. It’s features, reliability, consistency (we build and test Quadro ourselves; GeForce is made by something like 32 different manufacturers each with their own approach) and, yes, sometimes speed (due to chip-level feature differences like dual copy engines and such).
    And if you don’t need or care about those things, then GeForce might very well be a great choice for you. No argument there.
  • Tom Daigon
    October 1, 2012 at 3:09 pm
    I am curious to see how the soon to be released cards based on the K20 technology compare to my GTX 570 which is giving me great performance on CS6.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Jud Johnson
    October 4, 2012 at 1:55 am
    Greg, thanks for joining in on the discussion. Any idea as to when the K5000 will be released and its price?
    How would the K5000 performance compare to the other GPUs for PPRO?
    Jud Johnson
    Luxe Films
    http://www.luxefilmshouston.com
  • Jud Johnson
    October 18, 2012 at 12:13 am
    Greg,
    Do you know if the new K5000 will work with the Tesla C2075 in the “maximus” configuration?
    It’s not clear on the Nvidia website wether it will or not.
    Jud Johnson
    Luxe Films
  • Jud Johnson
    October 18, 2012 at 12:14 am
    Greg,
    Do you know if the K5000 will work with the Tesla C2075 in the “maximus” configuration?
    It’s not clear on the Nvidia website wether it does or not.
    Jud Johnson
    Luxe Films
  • Greg Estes
    October 18, 2012 at 12:27 am
    Mixing Kepler and Fermi is not tested, supported or recommended.
    It might work if you try it, but that would be very application dependent and when I checked with the product team they gave me the “not tested, supported or recommended” answer.
    It’s the technical dissimilarity, not a random marketing decision.
  • Jud Johnson
    October 18, 2012 at 2:26 am
    [Greg Estes] “Mixing Kepler and Fermi is not tested, supported or recommended.
    Then if i’m trying to build a “beast machine” to handle heavy PPro and AE projects…would i be better off in performance to use a Q2000 + Tesla, a Q4000 + Tesla, or a K5000 stand alone? This is where i’m confused.
    Thanks.
    Jud Johnson
    Luxe Films
  • Greg Estes
    October 18, 2012 at 4:45 am
    We are supposed to have some new benchmarks next week that include K5000. If I forget to post, ping me.
    In general the answer is going to be different if you mostly use PPRO or if you do a lot of AE. AE uses both GPUs in a system and works best when they are the same (GPU ray tracing with OptiX needs all GPUs to have the same frame buffer memory size, so it will default to lowest if they are different). OTOH, Premiere Pro uses only one GPU at a time, so for primarily PPRO use, a little Quadro and big Tesla is the best price/performance.
    So dual K5000’s would solve both problems, but if you mostly do PPRO then you might be over-spending.
    And, it must be said, Adobe does not officially support Kepler in CS6 ;-(
  • Jud Johnson
    October 18, 2012 at 5:06 am
    [Greg Estes] “OTOH, Premiere Pro uses only one GPU at a time, so for primarily PPRO use, a little Quadro and big Tesla is the best price/performance.
    We primarily work in PPro and want the fastest render/export performance available. So with that said, it appears that a Quadro 2000 + Tesla C2075 would be best for us…does that sound correct?
    Jud Johnson
    Luxe Films
Page 4 of 5
