Activity Forums Apple Final Cut Pro Mad audio glitch – FCPX
  • Mad audio glitch – FCPX
    Posted by Boris Jansch on September 3, 2012 at 4:06 pm
    So this is the wierdest and scariest glitch I have experienced since 10.0.
    In a nut shell, some of the audio in my project has decided to embed itself in the primary storyline.
    I am unable to remove it, copy it, adjust it and I have no idea what to do to fix it.
    I’m running FCPX on a 2010 imac i7, 8GB Ram, 2.93 Quad core with 256GB SSD
    Please see attached screenflow file.
    4620_fcpxglitch.mov.zip
    Many thanks,
    Boris J.
    Mark Morache replied 14 years ago 2 Members · 1 Reply
  • Mark Morache
    September 4, 2012 at 9:01 am
    Boris… I’ve run into this before, and I can’t quite remember what I did, but try this:
    Select the errant clip in the timeline index. This will select the clip and move the skimmer to the start of the clip. Press CMD-X to cut the clip, removing it from the timeline and placing it in the copy buffer. Now without moving the skimmer, paste as a connected clip with OPT-V.
    When I ran into this, after the initial shock of the bug, I remember it was actually fairly easy to remedy with the workaround.
    Let me know if this doesn’t work.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
