Activity › Forums › Blackmagic Design › MacPro with Multibidge don’t turns on
  • MacPro with Multibidge don’t turns on
    Posted by George Kalishkin on September 29, 2007 at 12:30 pm
    When i connect Multibridge Extreme to MacPro (2.66, 4GB, Radeon 1900, EFI 1.2) and press power button, cooler on rabeon begins loud working and screen becomes gray, but no startup chime!
    may it be with new firmware update for macpro?
    George Kalishkin replied 19 years ago 3 Members · 5 Replies
  • Kristian Lam
    October 1, 2007 at 1:25 am
    Don’t think it’s the firmware of the Mac.
    I would check the PCI Express cables to make sure they are securely fastened. Also check that the little LED light on the front of your Multibridge Extreme is lit up and not blinking.
    regards
    Kristian Lam
    Blackmagic Design
  • George Kalishkin
    October 1, 2007 at 7:08 am
    cables are tight screwed.
    led is blinking, what does it mean?
  • Kristian Lam
    October 3, 2007 at 1:11 am
    Doesn’t sound good. Could be a power supply issue either with the power adapter or the internal unit in the Multibridge.
    Does it run in standalone converter mode? Disconnect the PCIe cable, hook up USB and launch the Multibridge Utility. See if the options are available or greyed out.
    regards
    Kristian Lam
    Blackmagic Design
  • Steve Regian
    October 3, 2007 at 10:36 am
    Had this same problem several times. Unplug power and leave off over night usually works. Power up Multi before computer.
  • George Kalishkin
    October 5, 2007 at 8:44 am
    my dealer exchanged unit without questions, new one workink great.
