Activity Forums DaVinci Resolve MacPro + GTX260 : Intensity Pro Killed the GTX : anyone else?
  • MacPro + GTX260 : Intensity Pro Killed the GTX : anyone else?
    Posted by Gabriele Turchi on March 21, 2012 at 12:50 am
    Hi , i am wondering if anyone else had this issue i am having :
    just installed Resolve @ home (testing etc..)
    i have macPro 2009 8 core , GT120 + GTX260 (resolve report 1GPU (processing power) so all good
    today i have installed the intensity Pro , but as soon as i start the Mac Pro the fan of the GTX spinning at max speed and the system won’t see the GTX anymore …
    tried swapping slots …same issue , if i remove the intensity : the GTX show up again ..
    But the intensity card seems working correctly …
    anyone else ?
    maybe bad card ?
    thanks
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
    Peter Lewetzel replied 14 years ago 3 Members · 4 Replies
  • Gabriele Turchi
    March 21, 2012 at 3:54 am
    FYI ,
    problem solved,
    after swapping cards around in the slots (still the issue) i plugged the HDMI cable to the Intensity , and the issue disappear , fan of the GTX stopped spinning and the GTX showed up again ,
    i assume was a static electric thing that plugging the HDMI cable went away ..
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Esteban Aguilera
    March 21, 2012 at 9:54 am
    Try using the debug text, with the 3 lines.
    Look at the forum with the text “debug”
    Di Davinci Resolve Colorist
  • Gabriele Turchi
    March 21, 2012 at 2:37 pm
    Eastban ,
    it was an electrical issue between the card and the motherboard …the GTZ was going crazy the very second i turned on the mac pro …
    nothing to do with resolve software …
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Peter Lewetzel
    August 11, 2012 at 2:15 pm
    Hi Gabriele,
    did you solve the problem between your GTX260 and the intensity card? And how? I´m very curious, because I have almost the same thing: With the BMD card my GTX 285 is offline… I could make my configuration work sometimes by switching on the monitors in a particular order, but it´s not a solution at all.
    Thanks a lot for any help!
