Activity › Forums › Apple Final Cut Pro Legacy › MacPro Edit Suite
  • MacPro Edit Suite
    Posted by James Whittington on June 26, 2009 at 7:32 pm
    Hello!
    I’m looking to upgrade my current Mac tower (G5, PowerPC). I’ve got a budget of about $5,000 and have come up with the following setup…
    8-core, 16GB Tower: $3,800
    3 1TB Seagate Barracuda SATA drives: 90×3=$270
    CalDigit RAID card: $645
    That comes to $4,715. Is there anything else that you all would strongly recommend adding to that? Any major reason to upgrade the graphics card?
    I should mention I have a dual monitor setup that works fine as well as a Kona LHe card.
    Thanks very much!
    Steve Oakley replied 17 years, 3 months ago 5 Members · 5 Replies
  • Kevin Monahan
    June 26, 2009 at 9:06 pm
  • Zane Barker
    June 27, 2009 at 4:00 am
    [James Whittington] “Is there anything else that you all would strongly recommend adding to that?”
    Apple Care is a MUST!
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • David Bogie
    June 29, 2009 at 3:11 pm
    If you are going to be making money with this setup, you want a card specifically for Motion, the 4870 or 4780, whatever they’re calling it now.
    You want CS4.
    You want to replace the chair at your editing desk.
    bogiesan
  • James Whittington
    June 29, 2009 at 3:38 pm
    Haha…very nice.
    Don’t use Motion very often. Tend to use After Effects for all my motion graphics needs.
    Chair is sufficient but I wouldn’t be opposed to an upgrade!
  • Steve Oakley
    June 30, 2009 at 5:41 am
    don’t get the ram from Apple, get it from a 3rd party for a lot less
    why are you getting the raid card ? you can stripe a raid with the internal drives & OS X. raid card only makes sense to connect to external storage
    and that kona card probably won’t work because unless your G5 was the last generation, they have PCI-X slots, not PCIe. in that case, the kona card is a boat anchor.
    in which case you need to look at some sort of video I/O, and I think the better choice is the matrox hardware once you look at price / performance / options in product line including the h264 encode acceleration.
