Activity Forums Adobe After Effects Machine gun firing
  • Machine gun firing
    Posted by Guille Ibanez on March 2, 2006 at 11:18 pm
    Hi there!
    I’m new in this forum.
    I’m making a short film and there’s a moment on it when one of the characters
    gets out a big machineGun and starts shooting against another guy.
    Is it possible to achieve this with AfterFX? I mean, just the spark of fire that happens
    in the canon when you pull the trigger, lots of them at the same time.
    more or less like this but not so big:
    https://forum.apan-info.net/Winter02/jpg_lg/B-11.jpg
    thanks in advance
    Firstcinemapictures replied 20 years, 6 months ago 5 Members · 4 Replies
  • John Dickinson
    March 3, 2006 at 12:37 am
    This is called “muzzle flash”. I know that Digieffects Delirium has a muzzle flash effect. Artbeats also sells stock footage of muzzle flashes. Andrew Kramer might have some good ideas as well, he’s been working on this kind of thing lately.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Dan Asselin
    March 3, 2006 at 1:22 am
    You might also look at Particle Illusion if you have access as they have both flashes and spent shell emitters
  • Mike Clasby
    March 3, 2006 at 1:41 am
    You might want to check out these Detonation Film Freebies:
    https://detonationfilms.com/free_stuff.htm
    Tutorial (for Premiere and FCP, but can do with AE) here:
    https://detonationfilms.com/tutorials.htm
    Then for the repeat of a machine gun (600 rounds per minutes if my Infantry memory holds up, so loop it every three frames if 30 fps comp), use this loop expression:
    Loop_out(“cycle”,0)
    See Dan’s tutorial “Animating a Walk Cycle”, by clicking his head above, for details (and project file) on looping.
  • Firstcinemapictures
    March 4, 2006 at 7:18 am
    also check out this software.
    https://fxhome.com/effectslab/
    Darrell
    FIRST CINEMA PICTURES
