Activity › Forums › Media 100 › machine control problem
  • machine control problem
    Posted by Matt Short on September 12, 2005 at 5:11 pm
    Today when I launched M100i, I got the warning…’Could not continue because the package DQMachOSerial cannot be found’. I get this warning everytime I try to turn on machine control. I reinstalled the Keyspan drivers. The DQ-TimeCoder is in the M100>Machine Control folder. Any ideas?
    Matt Short replied 21 years ago 4 Members · 6 Replies
  • Joe Hayden
    September 12, 2005 at 7:42 pm
    I have a twin serial adaptor and sometimes I plug the cable into port 2 instead of 1 or vice versa.
  • Floh Peters
    September 12, 2005 at 7:43 pm
    It sounds like there
  • Matt Short
    September 13, 2005 at 4:18 pm
    Its called the Keyspan Serial Assistant and I had checked it. Everything is as it should be. I trashed everything Keyspan related and reinstalled the drivers and plugged in my other adapter from my other M100. Still nothing. Both adapters work fine on the other system. I’m going to call Keyspan tech support.
  • Lawrence Marshall
    September 14, 2005 at 3:23 am
    I had a very similar problem… turned out to be a bad Keyspan. I returned it and got a new one… everything works fine now.
    LM
  • Matt Short
    September 14, 2005 at 3:08 pm
    Its not the adapter because it works fine on my other system. Keyspan says it must be a M100 issue. I’m going to try reinstalling M100.
  • Matt Short
    September 18, 2005 at 10:35 am
    reinstalling M100 did the trick
