Activity › Forums › Sony Cameras › MacBook Pro with Yosematie will not read EX3 SXS cards
  • MacBook Pro with Yosematie will not read EX3 SXS cards
    Posted by Roy Stewart on November 26, 2014 at 7:40 pm
    Hi
    If anyone could advise re the following, I would be very grateful.
    I use a 17″ MacBook Pro with Express card slot in the side to dump my SxS cards from my EX3 when in the field. This worked perfectly until I recently installed Yosematie on my MacBook and now it does not see the SxS cards. Can anyone help or advise if Sony/Apple will be resolving this problem. I’ve tried asking these organisations already and got nowhere.
    If anyone can help, that would be super.
    Cheers
    Roy
    Matt Hoyle replied 10 years, 11 months ago 8 Members · 17 Replies
  • 17 Replies
  • Ian Cook
    November 26, 2014 at 8:21 pm
    We’ll be releasing an update for Yosemite soon. In the meantime you can use an SxS card reader (SBACUS10 or SBACUS20) or the camera. The device driver is only required when using the express card slot.
  • Roy Stewart
    November 26, 2014 at 8:34 pm
    Hi Ian
    Thank you heaps for the prompt reply and help. I assume you are with Sony.
    Yes, I did borrow a card reader for a specific which did work and I am aware I could copy from the camera but neither is as convenient as the Xpress card slot.
    Looking forward to hearing about the update.
    Thank you
    Roy
  • Jeremy Eccard
    December 17, 2014 at 3:43 pm
    We recently upgraded to Yosemite 10.10.1 – MacPro (Mid 2012). USB Transfers from US-10 using SxS are excruciatingly slow, more than double real-time. Before we were using Mountain Lion and transfers were much faster. Any suggestions?
  • Ian Cook
    December 17, 2014 at 4:15 pm
    You need to update the SxS UDF driver. The version you have doesn’t work under Yosemite (10.10). When the driver isn’t installed or isn’t working correctly you’ll have extremely slow transfers and the card will mount as read-only. Install the below update and you should be back on track.
    https://www.sonycreativesoftware.com/sxsudfdriver
    Ian Cook
    Sony Broadcast and Professional Services
  • Jeremy Eccard
    December 17, 2014 at 7:57 pm
    Thanks for the quick reply. Unfortunately that didn’t solve the problem. Any other ideas? Is there a way for me start over with clean slate, uninstall Content Browser and drivers?
  • Ian Cook
    December 17, 2014 at 8:09 pm
    try uninstalling/reinstalling and rebooting. if you are getting slow transfers after an OS upgrade it’s almost certainly the driver. this is exactly the behavior to expect when it isn’t installed or isn’t working. you do not need to uninstall/reinstall Browser but you do want to be at the latest version.
  • Jeremy Eccard
    December 17, 2014 at 8:24 pm
    Please excuse my ignorance. How do I uninstall the driver? I didn’t change the install location so it should be on Macintosh HD (default location).
  • Ian Cook
    December 17, 2014 at 8:28 pm
    System/Library/Extensions/SxS_UDF.kext
    If you see other ‘SxS’ items in here remove them and then reinstall just the UDF driver
  • Jeremy Eccard
    December 17, 2014 at 8:47 pm
    Thanks for the help! Everything is working normal again. There were several SxS Drivers installed – after removing them, rebooting, installing new driver, and rebooting again we are good to go.
    One more question, does the PDW-U1 work with Yosemite? We have an older Sony camera that shoots MPEG HD(HQ) and I can’t seem to get the professional discs to mount.
  • Ian Cook
    December 17, 2014 at 8:49 pm
    Glad it worked out. The Yosemite update for the U1/U2 is still pending but should be available soon.
