Activity Forums DaVinci Resolve Macbook Pro Resolve – Render Issues
  • Macbook Pro Resolve – Render Issues
    Posted by Jon Georges on May 8, 2011 at 7:42 pm
    Everything works great while grading in HD – However as soon as I try to Render the Video (on the Macbook Pro Screen) gets jumbled and it says GPU exhausted – Is there a way to Render the Project “behind the Scenes” so I can complete the Project – i.e without using the GPU to render? BTW – In SD Everything is fine and renders perfectly – Proxies have worked but only for grading – as soon as render starts it goes to HD and has the same problems. Thanks in advance…
    Jon Georges replied 15 years, 4 months ago 3 Members · 6 Replies
  • Peter Chamberlain
    May 9, 2011 at 12:49 am
    Hi, i expect you have reached the hardware resources limit. As a starting point, if your timeline is longer than 20 minutes try cutting it into segments of that length and only load the material needed for that 20 mins into the Media Pool.
    Peter
  • Rohit Gupta
    May 9, 2011 at 2:19 am
    Which Macbook Pro model are you using?
    How complex is your node graph?
    If you could send an exported version of your project at our support email davincihelp (at) blackmagic-design.com, we’ll like to have a look.
  • Jon Georges
    May 9, 2011 at 6:17 pm
    I am using an older Macbook Pro with 2.4 Core 2 Duo and Nvidia 8600GTM – I know its not recommended but that is the Computer I have and I need Portability – Also – 720P works fine as well so I have been rendering/timeline settings for 720p even though the footage is 1080 24P. Will I have the same problem if I upgrade to a newer Macbook Pro – Also – will the Version 8 work better with my computer?
  • Rohit Gupta
    May 10, 2011 at 2:48 am
    Is your energy saver switched off? If you can send logs and your project to our support, we can try to isolate the issue. It could be a GPU memory limitation as the Macbook Pros only have 512 MB of RAM.
  • Jon Georges
    May 10, 2011 at 3:34 pm
    Will the new version work better with a less powerful setup?
  • Jon Georges
    May 23, 2011 at 9:15 pm
    What I am wondering exactly is if I get the newest Macbook Pro, will I be in better shape than now with the macbook pro – Will the Ati cards have better support with the new Version? And what about the ThunderPort??
