Activity Forums Adobe After Effects MacBook Pro crashes when I connect ANY monitor! Help!
  • MacBook Pro crashes when I connect ANY monitor! Help!
    Posted by Lori Newman on July 28, 2021 at 9:56 pm
    I’ve been working in AE for years but now I’m in a situation that I can’t seem to find my way out of. After Effects works fine until I click on a subcomp. Then the wheel and that’s it. It doesn’t seem to happen when I work in other programs, which I don’t do that much. As soon as I add a monitor, 2k, 4k, portable monitor or even iPad Pro it happens. I have 3 months of deadlines coming up and I’m at a loss. I’m working on a MacBookpro 15″ 2019, 2.6 Ghz 6 core intel Core i7 with 32 GB ram, Radeon Pro 560x 4 GB. I also have an older macpro (garbage can) with 60 GB ram, same problem. I have cleaned off both computers and reinstalled everything. I am running BigSur version 11.4. Suggestions? I would be grateful for any help. I have called Apple, Adobe, both point to each other.
    Eric Santiago replied 5 years, 1 month ago 3 Members · 6 Replies
  • Eric Santiago
    July 29, 2021 at 2:02 am
    Hope its not Big Sur for starters since its a PITA to roll back.
    How are you connecting the displays?
    What kind have you tried?
    And its just when you connect external displays?
    What about resolution?
  • Lori Newman
    July 29, 2021 at 5:06 am
    yep, Big Sur… I just purchased a refurbished LG ultrafine monitor so I hope it will be more compatible, the 4k with thunderbolt 3 connectors. My other monitor is in the shop checking to see if there is any problem with it. It’s an LG 27UK850-W 27″ 4k UHD IPS monitor. I connected it with the cables it came with (tried them all). I think I settled on usb-c. I also bought a dock and tried to connect peripherals to that. It only happens when I connect external displays. The projects are 4k. I’m not sure about mixing 2k and 4k. I was using a Dell monitor which used to work fine with my old macpro. I’m pretty sure I also bought a cable that was supposed to work with 4k monitors.
  • Eric Bintner
    July 29, 2021 at 12:25 pm
    I have a 2019 MacBook Pro and had this issue last week. For me it was a standard HDMI cable that was the problem.
  • Eric Santiago
    July 29, 2021 at 6:17 pm
    Some cables are suspect but not enough to crash a system.
    Just to add I work on a ton of 4K to 8K projects on an Apple Cinema 30″.
    So no need to be forced into a 4K display if cost is an issue.
    I have Big Sur running on a 2013 Mac Pro D700 at home and so far so good.
    I sure hope you get that going.
  • Lori Newman
    July 30, 2021 at 3:33 am
    I used an Apple Cinema Display for years until it died. That’s when some of the trouble started. I have a Dell monitor 2k that has been fine on my older macpro system which has been more stable then the macbookpro. When I have tried to add a 4k monitor I had problems. We’ll see if my laptop works with the LG ultrafine when it arrives. I don’t think the 4k monitor that’s in the shop will work with my older machine…
  • Eric Santiago
    July 30, 2021 at 1:36 pm
    The Cinema res is a lot lower than a 4K display.
    I am hoping it’s not your laptop/Big Sur combo causing the crash.
    I have never experienced a hard crash by connecting displays.
    Glitches and screen tears but not a hard crash.
    But the in my years I have ran into bad (even brand new) cables 😛
