Activity Forums Avid Media Composer macbook pro and ExpressPro
  • macbook pro and ExpressPro
    Posted by Eli Tishberg on July 1, 2007 at 12:53 pm
    Avid says you can use MojoSDI on the MAcbook Pro but then later on in their document they mention “PCI Bus segments required for Mojo and Mojo SDI”
    Will I be able to use a MojoSDI with a macbook pro? I will obviously have the Mojo hooked up to the macbook pro, as well as a fw800 drive. Will this work? I would probably be digitizing 1:1 or 2:1.
    Thanks…
    eli
    Eli Tishberg replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
