Activity Forums Adobe Premiere Pro Mac seems to hate PP CS6
  • Mac seems to hate PP CS6
    Posted by Dominic Legg on October 23, 2012 at 1:57 pm
    Hello everyone.
    I am trying to get work out why I cant use Premier Pro CS6 successfully on my 8 Core Mac Pro – 2GB Quadro 4000 – 16Gig Ram.
    I have tried reinstalling a few times but the program does not seem to be stable? (both system and program) I have tested with Open CL on and off – Both the same… Program inconsistently crashes and is unusable. AE and Media Encoder works great by the way.. its only Premier Pro.
    There are no hardware faults and the ram is new and working perfectly.
    Do other people seem to have the same issue?
    On the other hand at home I have an X79 Intel 3820- 16gig ram – GTX 560 with a heap of plugins running CS6 and it works fine. I have only ever had it crash once…
    Is this a mac only problem??
    Should I think of moving the work computer over to PC? (hopefully stations will accept something similar to ProRes soon…)
    I have read through the Adobe forums and there are allot of inconsistent fault threads. I have tried all fixes to no avail…
    Motion Graphic / Video Editor
    Dominic Legg replied 13 years, 10 months ago 4 Members · 5 Replies
  • Chris Borjis
    October 23, 2012 at 4:06 pm
    I have the same systems (2 of them)
    and have not had those issues on one of them.
    The other mac developed a faulty mainboard and had
    to be replaced and now it has no issues.
    I ran tons of tests just like you, have you ran
    the system test long and short that boots from
    the other disc that comes with os x?
    The long test caused a reboot, the short test would
    report and error.
    what version of os x are you running, you have
    to have at least snow leopard 10.6.8
  • Dominic Legg
    October 23, 2012 at 11:42 pm
    Thanks for the responce 🙂
    The mac has been in for the’long’ hardware tests in the past few weeks as the new ram was mostly faulty. 3 chips supplied had to be replaced. The tests came up clean every time even though the ram was faulty to begin with. The ram died days after.
    I have experience the occasional CPU core crash / misfire but it is not a regular thing.
    I am running 10.7 on the system.
    It seems very random when the system crashes. I have been told to keep the sequence within the present settings but that does not seem to help. I mostly deal with ARRI Raw and Proress 422.
  • Kevin Monahan
    October 24, 2012 at 7:30 pm
    Folks on Mac experiencing problems found that updating to the latest CUDA drivers and the latest version of OS X Mountain Lion solved them.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Robert Brown
    October 25, 2012 at 1:31 pm
    I had heard that Mountain Lion was the way to go a few weeks ago and was having some issues. I still had them until the new Cuda drivers came out and it’s been doing pretty well. Another thing to try though is to turn Cuda off in the project settings and see if it runs any better.
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
  • Dominic Legg
    November 2, 2012 at 9:10 pm
    I have 10.7 (up to date) and Cuda Drivers are up to date also.
    Still no solution to this.. Also Using Premier pro seems to take ages to start playing clips off the timelines. eg 3 seconds..
    As mentioned it seems an entirely different beast on PC than Mac. I have decided I will not be staying with Mac next upgrade round.
