Activity › Forums › Audio › Mac Quad G5 and 5.1 Surround Sound (Dolby)
  • Mac Quad G5 and 5.1 Surround Sound (Dolby)
    Posted by Sjon Ueckert on February 25, 2007 at 6:55 am
    Does anyone know of an interface that can be used to output 5.1 Audio from a Macintosh? I have found a few (Gryffin Firewave and M-Audio 410) but I don’t know if they work with Final Cut Pro or DVD Studio Pro. I don’t need to mix 5.1 (although I can with Logic) I just need to be able to hear it. I have a Yamaha Surround Sound system that requies 6 RCA miniplugs, so that would have to be the interface’s output. Inut can be either optical out or fiewire.
    Sjon
    Rcpics replied 19 years, 6 months ago 3 Members · 2 Replies
  • Will Salley
    February 26, 2007 at 9:14 pm
    The 410 should work with FCP and DVDSP. The PCI based M-audio 5.1 card should work equally as well.
    https://www.samedaymusic.com/product–MDOREV51
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
  • Rcpics
    March 13, 2007 at 8:36 am
    If you want to go the ultra-cheap route, you can take the audio converter/controller of this headphone setup:
    https://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2217094
    ..which accepts coax or optical digital in (the G5 has optical in/out), and hook up stereo mini-plug to RCA adapters to the analog outs (C/L/R/SL/SR/SW) to get separate analog outs.
