Activity › Forums › Apple Final Cut Pro Legacy › mac pro hookup for audio monitor
Posted by Jason Brown on October 16, 2009 at 12:14 amHey Guys,
I monitor my FCP audio through my Matrox box…out to a Mackie 8 channel mixer.
I need to listen to audio from my MacPro sometimes…so I routed it through the mixer via a mini-plug to unbalanced 1/4 stereo plug into the mixer.
Problem is…there’s some buzz…very light…but I’d like to eliminate it. What are you guys using? D/A convert the toslink to balanced?
-Jason
Jason Brown replied 16 years, 2 months ago 4 Members · 9 Replies -
Alan Okey
October 16, 2009 at 12:20 amI use the balanced analog outputs from my AJA Kona LHe. No buzz.
Michael Gissing
October 16, 2009 at 12:28 am[Alan Okey] “I use the balanced analog outputs from my AJA Kona LHe.”
Jason wants to monitor his mac directly, not FCP. I have the toslink out to a convertor to SPDIF and then into a router which comes to my amp’s SPDIF input. My rooms also double as audio post so I have all sorts of digital sources to route & monitor.
From the Mackie, are you going to an amp? Many amps have toslink and SPDIF inputs so if you patch the mac to them, you simply change monitoring on the amp and voila, clean signal.
Jason Brown
October 16, 2009 at 12:43 amNo…the Mackie I’m using directly out to headphones or Control room monitors…no amp.
I’m thinking there should be a box to convert Digital to analog balanced. That’s all I need…doesn’t seem that crazy.
-Jason
Alan Okey
October 16, 2009 at 2:40 am[Michael Gissing] “Jason wants to monitor his mac directly, not FCP.”
FYI, you can also monitor Mac system audio through a Kona card. Just select the Kona in the System Preferences audio pane.
Michael Gissing
October 16, 2009 at 6:51 am[Alan Okey] “FYI, you can also monitor Mac system audio through a Kona card.”
Ahh, thanks for that Alan.
Jason Brown
October 16, 2009 at 2:35 pmInteresting…the only options with a Matrox is Line out/digital out/internal speakers
That’s actually a pretty big selling point for Kona over Matrox…wish I’d have known that before I bought 2 matrox boxes!
-Jason
Joel Wenz
October 20, 2009 at 4:53 amyup system prefs -> sound. Same works with the Blackmagic cards 🙂
Jason Brown
July 15, 2010 at 2:35 pmThought I’d update this post…
Matrox came out with new software (v2.0) that enables output of the system audio through the matrox hardware…similar to what we’ve discussed here.
