Activity › Forums › Adobe Premiere Pro › Mac Pro 2010 with ATI Radeon 5870 and Nvidia Quadro 4000
Posted by Kelly Chen on July 30, 2012 at 9:54 amHi,
I have installed on my 2010 Mac Pro:
Slot 1 ATI Radeon HD 5870
Slot 2 Nvidia Quadro 4000How do I get Premiere 6 to work with my Quadro? I want to use the Mercury playback engine. I have just switched over from Final Cut 7…….
Should I change the Quadro into slot 1? Would this effect other programs like DaVinci Resolve?
Any help would be greatly appreciated.
Dustin Ward replied 13 years, 10 months ago 6 Members · 12 Replies -
Chris Borjis
July 30, 2012 at 9:29 pm[Kelly Chen] “Should I change the Quadro into slot 1? Would this effect other programs like DaVinci Resolve?”
that would enable it to work with premiere, but then DaVinci won’t use it
for acceleration.annoying yes, but the way it is unfortunately.
Kelly Chen
July 31, 2012 at 7:22 amCurrently running OSX 10.8 and Cuda driver version is 4.2.10 there is a new update 5.0.17 but it wont install. Trying to figure the problem.
Kelly Chen
July 31, 2012 at 7:31 amBill,
You were right! New quadro drivers installed finally. Took 4 attempts. Now I can select mercury engine settings. Not sure Chris if I have to change over slots since I can select it, so win for Davinci and Premiere.
Bernhard G.
July 31, 2012 at 4:06 pmHello,
recently in a magazine I read CS5.5 had been tested on a so-called ‘Nvidia Maximus’ system,
which is a Windows PC with a Quadro2000 + Tesla C2075.Would be interesting to know if this means we could simply add CUDA-boards as we like,
and the more CUDA boards the better the Mercury performance will be (like in Resolve)?Or is ‘Maximus’ a method making two specific boards appear as one CUDA-unit,
so no additional performance for us here on OSX?Best regards,
Bernhard -
Vince Gaffney
August 2, 2012 at 6:34 pmKelly – are you still using the splitter for powering the cards? I just received tohe quadro 4000 and have the ati 5870 in a mid 2010 pro as well. any problems? thanks
Dustin Ward
November 14, 2012 at 11:56 pmHow did you get the ATI Radeon 5870 to work with the Quadro 4000 in your Mac Pro 2010? Thanks
Kelly Chen
November 15, 2012 at 12:16 pmHi Dustin,
Arty Black helped me with this one. He recommended to get a Y 6 pin splitter cable, like this one:
https://www.amazon.com/CB-6M-68F2-6-pin-PCI–Dual-Cable/dp/B005GWFZ8Y/ref=sr_1_10?ie=UTF8&qid=1314982428&sr=8-10Works like a charm.
Kelly
