Activity › Forums › Apple Final Cut Pro Legacy › Mac OSX crashes when firewire HDD & Sony Z1P connected
  • Mac OSX crashes when firewire HDD & Sony Z1P connected
    Posted by Philip Johns on July 30, 2007 at 6:56 am
    G’day guys,
    Just wondering if anyone has experienced this? I’m connecting a Maxtor 250Gb firewire 400 HDD to my Mac dual G5 2Ghz and a sony Z1P video camera and my system crashes. Any ideas why this may be?
    Phil
    Mark Maness replied 19 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    July 30, 2007 at 12:20 pm
    Try not looping things thru a device (connect each directly to a port) and make sure that the drives are formatted Mac OS Extended for starters.
    Might try connecting just one at a time to see where the problem lies.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark Maness
    July 30, 2007 at 2:03 pm
    Good advice…
    Let me ask you this? Are you trying to capture from your camera to you firewire drive thru the same buss?
    If so, I bet you are getting dropped frames. If you ARE capturing from the camera to a firewire drive, they need to be on separate busses. For about $35 – 50, you can purchase a firewire adapter card to put in you edit station that will solve this problem.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
