Activity Forums Adobe Premiere Pro Mac can’t see external fibre drives after updating OS X
  • Mac can’t see external fibre drives after updating OS X
    Posted by Steve Hobbs on December 29, 2016 at 1:08 am
    I am using a MacPro for video editing and just updated the OS X to Yosemite. Everything seems to works ok except my Ciprico MediaVault 4210 fiber drives don’t show up. They are not showing in Disk Utilities. I’ve tried rebooting several times. Any ideas?
    Chris Borjis replied 9 years, 8 months ago 3 Members · 2 Replies
  • Shane Ross
    December 29, 2016 at 1:12 am
    Are the drivers for the Fibre card compatible with Yosemite? Sounds like they aren’t. See if you can find drivers that are compatible with Yosemite…contact the manufacturer or look on their site. And hope they have updated drivers. If not…back you go…
    One of the dangers of updating to new OS versions.
    Shane
    Little Frog Post
  • Chris Borjis
    December 29, 2016 at 10:26 pm
    Ran into that as well (and I have that same storage device)
    The entire issue was an older ATTO fiber channel 4gb card.
    Also I tested an apple branded fiber card and that didn’t work either.
    At that time coincidentally I moved a caldigit storage array from another room
    that was much bigger capacity and needed there. It was pci-express direct and works
    fine in yosemite though.
    The only solution since ATTO didn’t make an updated driver for the card i had
    was to spend almost a grand on a newer one that did have a yosemite driver.
    I declined that idea and now have it on one of our legacy use systems running mountain lion.
